perfect for a can cable
what in the heck are they tryna get from the motors with like 8 sensor pins?
5V
GND
A
B
C
temp
bullshit
ego?
u r not supposed to spill their secret
I think 2 of them just make a BS handshake with their esc to scare users away from DIY
who wants their tiny motor anyway
This is the same shit they did with the GTR but the wire was just on/off so you could just leave it out and it’d work fine. Fucking evolve BS is why I started DIY in the first place.
male product code: Z1115AGP
female product code: Z1115AMP
| Rated Voltage | 48 V AC / 60 V DC |
| Rated Current | 25 / 2 A |
| Max. Contact Resistance | ≤10 mΩ |
| Max. Insulation Resistance | ≥20 MΩ |
| Material Of Contact | Copper Alloy |
| Contact Plating | Gold over Nickel |
| Protection Degree | IP67 |
25a per phase, what’s that work out to in terms of motor setting? About 50A?
Seems pretty neat for small builds
maybe 40? unless u pulling constant amp, i don’t think it matter that much if 40 or 50a
…with multiple motors ![]()
Yepp
I want to make a truly stupid setup with 3 of these for 6 phases + 12 sensors
Split and recombine each wire?
Yup (if I understand you correctly)
Motor 1: Phase A,B on Connector X
Motor 2: Phase A,B on Connector Y
Motor 1,2: Phase C on Connector Z
Same thing for sensor wires, but double everything
Edit: Side note, I now understand why scientific notation reuses conflicting symbols, just glad I didn’t have to use Alpha and Beta
Have connector Z above and in the middle of the other two to form a triangle for neater wiring. Glue the 3 plugs together and have both motors connect with the one master plug.
yeah exactly I just didn’t want to make the notation even more complicated by mixing the order in the description
QS10 is big af, r u sure u wanna use that
Hahahahaha no absolutely not, I just like imagining it as a silly design you get when you don’t give the engineers proper constrains
“So you want no gromets or separate sensor port, using as few parts as possible, and an off the shelf connector? I got you bud”
150mm lateral spacing of just end to end connector and goddamn 4AWG class conductors
