they are cool, but I am planning also to buy a gear drive and that’s where I got confused, because idk which one i need, dose someone know what gear drive should i choose
i am using 65100 motors from bioboards
From memory, the phañtom hubs follow the mbs pattern so thats what youll require for an adapter plate. I should know for certain as i own two sets but i dont can just remember fitting the radium pulleys and got a match
If the pulleys are bolted on using the only available bolt hole pattern, that is not MBS. I don’t know if any of the typical drives would work with those (Boardnamics, Newbee, 3DS, Apex, etc). You might be able to check if Omni has a set that works, or message Boundmotor and ask. My suggestion would be to get a different set of wheels with a more “universal” bolt pattern for more options.
