A far better option would be to put them inside of a motor can.
nice and sloppy
you should really consider your bushings setup. that top cone looks a little sad.
It works like a charm, function over form.
The bushing setup is actually pretty great, good carvability and stability at 26mph. Might just be the angle
awesome, each to their own, but I that kingpin nut I cranked down pretty hard…
My best performing setups also have really soft bushings that are cranked down way over what they should be. More stiff bushings and less crank-down just has me feeling less in control of the vehicle.
What mesh did you use?
Amazing! Probably more economical then simply buying stainless steel mesh
Yeah, it was avialable here and now, around 0.79 euro
Way cheaper than the 10$ I saw on amazon for stainless steel mesh.
I am 1000% doing this thanks for the idea and pic man!
Actual 10000iq play right there
