Hi everyone I have all my gear arriving for my build early next week. Running the Maytech 6374 sealed and wondering if anyone has had any luck painting/colouring their motor?
I really want to match it to my trucks (Satin Purple) and esc cover which I will also be painting.
Not sure if there will be issues with the paint in regards to insulation and heat retention but would appreciate some advice.
I’ve also thought of just shrink wrapping it but not sure if this will work.
If nobody has tried this before I’ll have a crack at it and see what I can come up with, if there is a tried and true method please let me know so I dont f*#k my brand new motor lol.
You can paint cans no drama and to be honest if the can is getting hot enough to need heat resistant paint then you are in a bit of trouble. Remove the cans to do the job though so make sure you get some good advice from someone that knows those particular motors because its sometimes not all that straightforward.
Its a sealed motor so I don’t think I will need to take it apart, just mask up the area I want to colour. If I do take it apart I will probably battle harden it just because I’ll be in there. I’ll see how it plays out.
Disassemble your motor can, go to a body shop and ask them to paint it with car paint, it’s the best way to make as they know the car paint tricks, if the painter is your friend he may not charge you back, otherwise buy him a beer as the ammount of material used is neglegible
