You can, but unless you get the battery the kit isnt good value at all
Any plans selling that carbon AT deck?
Yes, if you need only Carbon AT deck, You can contact with us. Ownboard@hotmail.com
We dont want to release in our website
How much would you be selling the the off road kit for?
looks like a great kit. What size are those motors?
Is this the same as the ones on the ownboard carbon board?
No one else is offering a AT kit
Are they using caliber clones? If so, can i mount those motors on my existing setup? I have a vanguard deck with caliber trucks.
I have a 10s4p 40amp max battery and I am looking for a hobbyking esc to work with a pair of racerstar 5065 200kv motors. Would the esc that ownboard is selling work? The hobbywing esc that ownboard is selling does not list if it is for hub motors or belt motors.
Its for hub motors. The hobbywing belt esc is apparently very specific with the component set it will work with, those motors may not work with it. If you really want to try, you can buy a hobbywing belt esc alone here (Select V2 Pro)
how do you get the pulley off the motor shaft?
Its like glued on or something
heat, use a small blowtorch to loosen the glue
