Hey guys.
Does anybody make a 240 hanger truck with outside king pin?
Im looking to replace some heXL trucks and keep my twin 6374 motors.
Thank you very much.
Hey guys.
Do you mean rkp when you say outside kingpin? Just wanting to clarify…
If it is what you mean, i think the only real option at that size is the fatboy hanger
I think he means TKP? Hell, I don’t know
Look at Surf Rodz, PiA to order from but good gear.
Is T for traditional and R for rear?
If so RKP.
The acronyms are not crystal clear
Reverse kin pin is possibly the correct acronym
yeah it is reverse kingpin
if you are trying to keep the same mounts you will have to buy the same style trucks
Thanks man.
Im happy to buy the mounts but it seems sourcing trucks is the problem. I see some use a 220 hanger with spacers.
why does it have to be 240mm specifically?
the only trucks of that length are fatboy trucks
and you can go slightly longer if you get lacroix]
or maybe surfrodz can come that long i dunno though
Because I bought a psycotiller complete but the trucks are ticking timebombs. It has 240 hangers atm with only 10mm clearance between the motors so with a 220 hanger Im 10mm in the red.
ah ok
then if money is with you go fatboy they make the most perfect trucks out there and i think he can even customize your name on them…
he sells 260 hexl which might even fit your mounts??
The hexl part would certainly fit my trucks but I still dont like that setup of bolting the hanger on. I would rather buy a top shelf complete truck, fatboy seems to have hangers only in stock
You can also buy baseplates from them separately or if you buy there caliber hangers they fit onto pretty standard basepaltes
I got my BN220s. Should be wide enough because the axles are longer than Hexl despite being only 220mm. Also available as a full truck and more than happy to bundle some mounts.
This trucks will work and come complete with mounts.
He is shipping from Taiwan, took two days to Japan.
The sold out is strong on the fatboy site lol.
@3DServisas any chance you can help this man out
I can’t recommend these highly enough, and the seller is amazing.
Yeah, I’ve got 220 Boardnamics, E-calibers and Surfrodz Hexls. The Kahua Trucks I like the most out of them.
Haggyboard.com was the best buying experience I had in a long time!
wow those kahua trucks are awesome and an awesome pirce…
gonna snag myself a set
Thanks guys. So I think Ive been focusing on the hanger length of 240mm when really I should focus on the 31cm total axle length.
Spacers can no doubt take up the slack on the inside of the wheel
