btw that’s some sicko longboard wheel car u have made there…
I guess road needs to be super smooth like on race track to really benefit from riding it
You can’t use 320 x 240 displays unfortunately right? It’s 2.00" too but higher Pixel density
Using ST7789VW sadly
Not with the current code. ILI9225 drivers are needed.
Your library for graphics is not adafruit GFX?
I’ve seen some tft-util.h included, it had tft 22 ili9225 in it
Dumb question and I know you won’t change it, but is there a reason why you avoided the Adafruit GFX library for the GUI? What files do I need to rewrite with the display there? Great you’ve already made a tutorial on how to change things displayed on the tft
Could you give an explanation on how to approach the usage of the more dense 2 inch 320 x 240 pixels display?
Also I think the Adafruit GFX library would be great to have
What a jewel!
This project has taught me a ton. I love where it’s at. Thanks dude.
So you use FW 3.58? You need to install an older version of VESC tool for this right?
Or do you have the firmware file?
It’s an old vid. Sean was one of the first guys to get the X.
And yes, you need FW 3.60 or older for for the OS DAVEGA.
Sorry to bother you, but can you get the firmware file somewhere?
Or do you really have to reinstall vecs tool (to what version for 3.58FW?)?
Re-installing VESC tool should be easiest. Not sure about the version. You’ll need to find out. This probably helps: Precompiled VESC Tool Archive
Hi @janpom , I have a Bioboards Davega x 1.0 (thank you @Skyart).
I’m going to use it with a stormcore 100d+.
I’m assuming it will need several firmware updates. When updating firmware should I perform updates sequentially - or should I just go straight to the newest version?
Thank you ![]()
Edit - I meant to post this in the davega x thread. I can’t repost and delete it here “too similar” error. Oh well
You can go for v5 straight away. Upgrade to v5.01 - DAVEGA
