So I picked up some freebies,
It seems dickyho Paris mounts will fit on the round axles.
My question is, when mounting these to the deck, it seems one set of bolts, the outer bolt, needs a nut, the other hole goes into the spring hat, is this for tensioning adjustment only like newer trucks or is this to also secure it to the deck? If the former, is it safe to run these with only one set of mounting bolts? Seems like it wouldn’t be too hard to break them free from the deck with only one set of bolts.
