OK Thanks.
Alrighty @KaramQ I’m gonna put your skillz to the test. I need a 20”x4” fat bike laced front wheel, bonus points if it comes with a tire. I can’t find this shit anywhere short of ordering from China.
Need a search term for something I want
Basically, it’s an insert. I want to drill a hole through the deck, insert the insert through the top and have a sort of thin lip that stops it from falling through (like you’d do with a bolt and a washer but nicer looking)
Maybe @b264 would know?
Don’t you need a rivet gun for those?
Not really, with a long screw and two nuts you can install them, tighten the two nuts against one another and flush against the rivet and thread the screw in.
Cool. Do you know if a bolt can be inserted from the opposite end of the rivnut? These would be installed from the top of the deck but I’d be screwing the bolt from the bottom (I want a maximum of security)
you are right though, these nuts are for sheet metal and compress when you tighten them i believe, or with a rivet gun (not sure actually).
Yep. This is what I used on all my boards in 2016-2017. I just use wood inserts now.
I’m pretty sure either way works
T-nuts maybe
Sex bolt or female barrel nuts is correct
What about a miniature selfcentering thumbwheel throttle rocker switch with 5k linear resistor ?
And what are your trics for searching?
I can be quite obsessive when I am convinced what I look for should exist, but finding it is another matter…
VPN to ensure matching regional coverage?
Multilangual input?
Good with search strings parameters?
@walter i usually go down a rabbit hole of related words and eventually manage to mashup all the correct words to get to the product
are these what you mean?
Not sure about the miniature part
I do the same, but also sort the hits by ‘images’ a lot since when its a more obscure search.
Like the model found by @b264 a lot, easy to adopt by redneck-glueing and modding.
Prefer 3D-printing a housing but due to the iterative nature of getting satisfying result dislike that path because I don’t have acces to a 3Dprinter.
Viable!
Sturdy, will survive plenty of bailings, not the flimsy playstation switch.
Size is managable, the ears can be cut off probably.
Look at the middle product in my image
