Hello in the uk and I’m. After rwo of these Maby someone knows where to get them thanks
I don’t know if this helps you being in the UK but…
You can get them direct from vxb here
Or through amazon here
MR2410-2RS Radial Ball Bearing Double Sealed Bore Dia. 10mm OD 24mm Width 7mm https://www.amazon.com/dp/B00IPSYHJY/ref=cm_sw_r_cp_api_i_V1fVEbSKHF2BM
If you want metal shielded it’s MR2410-ZZ
Sad. Face. In. In the uk
