If you’re willing to lean 45 degrees and not getting 1g avg 0-40mph we can conclude your motor and/or battery is too weak.
you’re avoiding the word “tie”
Will they cross the finish at the same time?
Assume the force of the motors is so weak that almost no lean is needed to stay on the board.
you wouldn’t know if you can cause you don’t ride
i know i can
The question isn’t well defined enough to give a certain answer.
your question isn’t well defined either
Two boards capable of 10N of force going forward with riders on them that can lean enough for this tiny force.
One has the bottle in their pocket and the other is holding it in front like in your AI images.
Which one passes the finish line first ?
fwiw, it’s obvious you feel that the limits of acceleration are currently constrained by ability to lean.
the example was just to make you admit that there are other limits at play here practically. most people don’t have unlimited thrust in their feet. or motors. or traction. which in your style you did concede.
it’s also true that any added mass beyond the balance point of max thrust is solely added mass which decreases total acceleration. but when that topic is put forth, you simply refer back to the unlimited thrust available in your feet.
it’s not clear that wish to persuade anyone or explore wether your theory has any flaws in it.
i can only assume you’re just trolling at this point. possibly realizing or not realizing your mistakes. but i don’t think you care that they might be there.
If their bodies are the same angle, and one of them is balanced, then the other one is tipping over.
bruh how would one fall over if the board is barely rolling forward?
I think I might be losing braincells rn
Suppose the one holding the bottle at their waist is balanced, the one with the bottle forward is tipping forward, and my not reach the finish line.
I’m starting to think maybe you don’t have legs and that’s why you’re so confused as to how they work. Why do you think people fall over so easily?
For the record Jackson owes me 50 dollars, so you should just venmo me instead
If your acceleration is limited by thrust then adding the bottle won’t do a damn thing.
And you kickpushing isn’t limited by thrust? You don’t have the thrust in a kickpush to achieve 1G, so your entire idea is bullshit and has been thoroughly disproven.
If I can get my foot at the end of the kick behind me to beginning of next kick in front of me in less time because a bottle is tipping me forward, then more kicks per minute = more watts, even if each kick is the same strength
What happens if you throw her off the back of the board while riding?
Oh wait, she’s imaginary so the weight would be 0.
Maybe lean harder if your massive hog allows it?
I usually don’t need the extra thrust while she’s esk8ing because my dogs give a pretty good pull…
even if you’re standing straight up, the bottle is gonna shift you com to the same as the person leaning, sooooooo
if only thre were a way to make the skateboard accelerate without requiring your feet to push…
oh wait
