Nothing more to say :)
Car salesman says “all the cars are sedans made by Ford or Nissan, same ones used by NASA”
So, obviously you get the best cars ever.
Then when you drive off the lot, it’s a 1985 Ford Escort(Laser) with 300,000 miles (500Mm) on it and rusting apart. That NASA doesn’t even use. And it’s been in 3 major wrecks, repaired by the lowest bidder with junkyard parts. But it’s a “Ford or Nissan sedan!”
That’s exactly what you are saying here, except cells instead of cars. Both LG and Samsung make great cells and shitty cells, and they’ve been making cells for a long time. You can buy knockoff cells and B-grade reject cells. You can buy used cells, and cells that have water damage and leaking electrolyte.
So your statement is a bunch of hot air with absolutely no meaning whatsoever.
