Yes. Theoretically a motor should be able to get up to its rpm limit regardless of weight given enough amps.
You will see the losses start stacking up with heavier loads because youâre using more amps to achieve the same rpm and there are more heat losses with higher amp draws.
On the flip side, when your board is unloaded on the bench, itâll pull low amps and get to top speed quickly without racking up as much heat.
@Athrx generally you want a lower angled rear plate for stability at speed. Iâm running 50 in the front 30 in the rear.
While I canât point out someone who has put these through the ringer in our application yet⌠only time will tell, but all discharge graphs/tests point to it being better than the 40T.
For my dual focbox set up took a shit today, just wondering what esc I should buy now, I know the stormcore is coming out soonish and torque board is coming out with a new one as well, i really donât want to wait for those and just want some recommends, money isnât an issue.
Anyone know where to get some ATS Truck Motor Mounts? Buddy of mine was trying to run some 3d Printed mounts and took a dive today after they (mounts and Pulley was 3d printed) fused together.
Looking for a good metal alternative and not sure he wants to upgrade to the Matrix II trucks + get mounts.
