:grinning: :hugs: jkjk
triggering your ptsd?
They just have to be moved out of the lane… just moved, maybe bumped… maybe punched… out of the way… even though they aren’t even in the way…
6.30…Are you already up or haven’t gone to sleep?
Yeah probably that second thing
Good morning all. I’m hoping someone can help here. My friend and I bought VX2 Pro remotes. We are both using vesc-x esc’s reconditioned by the drvwiz. We updated the firmware on all esc’s to 5.1 from ack’s 3.01 so the uart remote would work across the canbus. We were able to turn off reverse as well. The only issue is the the telemetry is not reading out properly. The remotes have been calibrated and setup correctly based on our wheel sizes etc… We turned on real-time app data as well. We can ride around using them no problem. Would anyone have any ideas to try to get the telemetry working right? I’m beginning to think that it’s just the older hardware in the vesc-x causing this problem. I actually bought a VX1 because I prefer just a simple remote using PPM. However my friend would like to use his and get it fully functioning.
We are looking at the BKB Xenith as well. Jared tested them and confirmed they work. Today is the last day at $199 as well.
Thanks a bunch for any help.
Really struggling trying to use the mobile vesc app, just can’t get it to work, how do you delete / wipe vesc settings that were made with a pc ?
So I can start again using the mobile app.
Thank you
tried using a dremel to route a hummie deck slightly
didnt get very far any advice?
or is there anyone in the uk with a router who would be willing to do that job for me?
just finished my battery
what test is the best to make sure everything is good and wont blow up my vescs when i plug in?
measuring 42.7v at 12s which i believe is fine
anything else i should check?
What’s the per cell voltage going into making the pack? Also check the charge port and the discharge port (even if you are not using it, it verifies the balance leads are good)
Try swapping the Rx and TX wires.
Everything seemed good so I plugged in to a vesc and this happened
No spark just lots of black smoke
No idea what happened
Did it smoke immediately? Are you sure the polarity at the connector is right?
I wired the battery backwards
So I plugged the esc neg into battery positive
My bad
Luckily battery is still measuring 42.6v
Yep exactly that
I got polarity backwards
Smoke immediately
Gonna rewire my battery main terminals
Exactly
Honestly freaked out as I saw it happen thought my house was about to explode
Gotta be more careful next time
I thought I made sure I got polarity the right way but seems not
I was concerned for you before, now I’m worried. Is there a buddy close to you that can look it over?
Not sure
Where you talking to me?
Yes.
