Looking for validation / recommendations for changing the default settings on EOVAN VESC.
VESC Settings.pdf (1.4 MB)
Attached is the Vesc tool 2,06 reading of the default settings and the proposed changes.
( info collected from topic on reddit and previous threads here)
Reduced Motor Current Max from 100A to 60A
Change Battery Current Max Regen from -60A to -20A
Change the Wheel Diameter from 108mm to 120mm (CloudWheels)
Enable Current Smart Reverse, which allows to slowly reverse
Change the Throttle Curve from 50% polynomial to 38% natural.
Reduced PPM Ramping Time from 0.45 pos and 0.15 neg, to 0.20 and 0.10
Power suddenly cuts off when starting to accelerate from stop (Not sure what to change)
Any other changes from the default that would be recommended
Thanks
