Hi once again in the build thread area!
After having 4 Slayer themed bigger boards, as many of you do I also wanted something lighter and more portable for running errands and what not.
Original idea was a 34inch old school style cruiser deck from skateshred.
Still need to sand it, re heat it in a few places, shape the edges to the deck once it’s routed and give an epoxy based coat.
Extras: need to 3dprint risers with led support.
Figure out the remote.
Flipsky antispark is coming.
I think the theme of the board was apearant from the first pictures, so keeping it I will get some green washers, wire sleeve etc.
Originally this board should have a davega some time in the not near future.
Originally this board should have a davega some day, for some reason I thought it shows individual cells. I don’t t why I thought that. So switched the cheap small eBay bms, to a cheap eBay Bluetooth big bms.
Extras. Sanding and top coating sanding and top coating.
I’m waiting for a push to start from flipsky, but for now will run a simple loop key.
Need to figure out the remote for the vescs.
Still need to get some 3d printed parts.
X makers one freezes, gets stuck, doesn’t send a signal each time when it does work.
The old maytech one, don’t know if it’s the receiver, remote or what, but when Vesc tooling ppm mapping the signal is going all other the place. I used to that remote behaving like this, but this time it never settles.
Noob quotations. Does any Vesc, work with any Vesc tool and any firmware? Do / can these things have something to do with crazy PPM?
