@DEEIF Skrew you and your dibs! I’ve been begging for months
Mine!!
Well I’m fine w sloppy seconds.
@MoeStooge , I’m not familiar with the sunmate 93mm pattern.
Would those bolt holes mate with the etoxx 5 hole at 40mm pitch diameter bolt pattern?
No, they have different patterns
Can be adapted to any 5 bolt pattern wheel.
Gotta measure and drill. The carrier bearing does all the centering runout…
What is the diameter of that gear?
Wow, 120mm gear is HUGE
It’s big. Will give us a 7.09:1 with the 11t pinion and 8.66:1 with the 9t.
11t puts our 800kv motors on a 52mph final drive for short track racing with the 150x50 tire.
The 9t was a short run prototype we ran with the 67t spur. It worked ok but were expensive for the service they gave. The 11t we can run hardened and will last longer for less cost.
Biggs is goin’ BIG
Thanks for doing all the testing before putting it to market!
Over 50mph is insane!
These videos are just more proof I’m on the wrong coast
haha, that scooter had to speed up when he heard you gaining on him.
Mounted up nice. Sounds good on the bench. Time to put on some miles .
Sounds awesome on the bench! Will you be coming out this Saturday?
Most likely. I think Mario will have the
La-KhymeraProtoLinko out. I would like to get some time on the spurs.
