SKP 18S7P Molicel 42A
SKP Solo Dual VESC
SKP 6485 Motors 138KV 10mm shaft
SKP (Z.Mote) Finger Trigger Remote
3dServisas Finality AT Gear Drive 1:4 10mm shaft
3dServisas Channel Trucks
3dServisas Aluminum wheels for 8.5x3 tires
Hota 8" Scooter Tyres
Rammboard Paragon Deck
Tomiboi Carbon Fiber Covering for Paragon Deck to make usable for 190lb rider
DaVega X Telemetry
metr Pro Solo module
Dual LED head lights and tail lights
I still need to add grip tape (and foot strap) before I put it through some hard riding.
But it has a pretty good footprint as far as contact area is concerned.
This thing is nuts! You’re going to have an insane amount of power depending on your settings. Two things I would warn you about is those tires are very good till they’re not. Once they start slipping on track or with heavy carves, it’s game over. Second thing is a front binding. If you’re planning on ripping that thing to its full potential, I would definitely consider at least a half binding in the front. Other than that dude, stay safe and have fun ripping that beast!
How’s flex feel? I doubled down on the CF to try to stiffen it up from the top. Honestly, it’s probably one of the nicest Carbon-fiber lay-ups that I’ve ever done.
It is much better now with the CF overlay. I like the amount of flex it has now…before it sunk nearly to the ground and it would have bottomed out on a bumpy right.
I was thinking the carbon would ruin the look of the board, but quite to the contrary, it’s pretty wicked looking.
Nice job! Thanks
