Agreed. Dookey charge port
They’re adequate but there are better options
If the one glyphiks made has a female thread, then it might be a great alternative. Genuinely surprised the cap they provide isn’t threaded while the connector itself is.
I have noticed as well that the battery charges relatively quickly. Left the battery after last nights ride at 55.5V. Charged it for maybe an hour and a half and it already got to 65V. I’m using a 6amp charger, but still feel like that’s still very fast ![]()
Nah, ive only ever used gx for sensors… and the nefarious balance port on Madness. Ive only made caps for weipu.
I’d design it ever so slightly undersize and print with tpu, no thread. Would be fiiiiiine
This is also the case for CN linko GX connectors. The rubber cap is not at all intended for an environment with vibration (esk8). It would be fine for a panel mount in a room.
I’ve put some 5min epoxy on the outside now, hopefully its grip will last. If not I’ll buy these threaded gx caps from aliexpress.
Have done about 250km on the board now. Longest on one ride being 70km and the others have been me commuting 40km going to the gym.
Despite the front truck being DKP, the stability from the riptide bushings ( barrel boardside and cone roadside ) has made going 35-37mph stable, while still giving me the turn radius needed for sharp turns.
The board will probably turn into my daily driver on non-rainy days at this point. Easy to store, essentially unlimited range, no fuel/parking costs and extremely fun. Low profile as well in case the wrong people are around.
Is there a reason why u guys decided on the TKP over RKP’s or just personal preference ?
I had never tried them, and onsra offered, so I thought it would be fun
I don’t think reverse kingpin trucks would provide enough clearance for the motors to not hit the deck on turns. You’d need a RKP truck with a high angle to barely make it work, not even sure if this exists.
Other issue would be the turn radius wouldn’t be great. Hummie deck kind of has a long wheelbase already and RKP truck characteristics ( despite having shorter wheelbases than TKP, DKP) wouldn’t help with turning at low speeds. Been a while since I did this research so someone correct me if I’m off about this.
I’ve been struck down by the karma gods for choosing a non smart bms for this build. Over time my board has slowly been charging from full 67.2V down to 66.2-66.4V. As a battery noob I first thought maybe the winter temperature drop affected the cells max voltage. It was only 5% drop so I wasn’t too bothered.
I come back from a long ride and try to charge it but nothing happens, and it turns out that the first two packs were sitting at 2.6-2.7V while the rest were at 3.5V. I’m assuming the bms thought these were flat so didn’t start charging.
Valuable lesson learned today!
Yup the BMS is correct that they’re flat lol
Unless something else also went wrong, they shouldn’t be meaningfully damaged, but the gap in voltage is a bit suspicious. To be clear, being at 2.6V isn’t likely to cause serious damage, but it’s a sign that something else has gone wrong
Molicel puts the minimum voltage at 2.5V, and cell damage is a sliding scale depending on how far below that it goes and for how long. It’s possible you got a few bad cells, or that some of the welds are dodgy. Bad welds would mean that groups 1&2 are effectively 5P or 4P instead of 6, so those will discharge much faster.
