⚠ Nexus Boards UK - Clearance Sale
The wiring doesn’t come with heat shrink, but I have loads if you want me to quickly just add some in there :slight_smile:
What will it cost? To be honest i used my last money on your parts and an focbox.
I cant see any heat shrink tube for the enclosure on your site…
An gasget
@Anubis Mr60 back in stock?
Yep :smiley:
Fastest delivery from ali i’ve ever had. 5 days to my door
@Anubis is there a way to disable auto turn off for the Flipsky antispark?
Maybe @Gamer43 knows
No.
Is there any way to disable auto turn ON? Some setups can turn themselves on when idle
Also how would i go about using it with an esc that has its own button to turn on?
Would i need to use 2 buttons? one to activate power flow via antispark and the second to turn on the esc? Just connecting power doesn’t turn the esc on
Short the switch on the ESC so its always on
I’m about to pull the trigger for some more goodies for the Omakase build but i need to know if these pulleys (with Whoosh mounts) could fit in regular Caliber II + dual 6354, thanks!
no, press fit pulleys need more axle space. You’d need e-caliber trucks or BN trucks.
Regular Caliber II are kinda shit. I highly suggest getting a BN Hanger (lots of my builds cheap out and only use a BN hanger on the back), yes I sell them so clearly im bias, but your pulley options are extremely limited as it is with 6355 on Caliber II. You can only use 12mm wide maximum and you have to mount everything very close together, not to mention it won’t even work anyway because the axle length on Caliber II means you have to use bolt on pulleys or shared bearing pulleys which aren’t really produced anymore
Even e-caliber you’d need 12mm pulleys i think 16mm is too wide for 6355, plus ecaliber bend even for normal use
I think it fits, worst case you add a single speed-ring to offset the 16mm pulleys
And whooshboards mounts are a mm thinner I think anyway
Yup, fair enough :laughing:
I was trying to reuse some parts i have laying around but i guess i will just keep the caliber baseplates for the BN hangers.
So this will go to the omakase build:
plus Whoosh mounts & blue caguamas :love_you_gesture:
Any idea which belts do i need for that set? I see you have some in stock but still not figured out which size is the correct one.
if u have the centre to centre distance of the whoosh mount, then i can tell u what belt length u need
75mm apparently, i’m going for 14:36 ratio, thanks!
