Not quite. Plus, those TB ones arent perfect. 180deg grub screw orientation is a bit silly, mine will be 90. Also those can’t be 3mm grub screws, they’re 4 otherwise they’d be the same size as mine
Not perfect, true. But out of all motor pulleys I’ve used they were the absolute best ones.
For the screw on the outside you need a 3mm key
Inside the teeth should be 2mm (don’t have a 2mm grubscrew atm but the 2.5mm one doesn’t fit.)
Your pulleys require a 1.5mm key
Nice!
Any estimates for when 18T will be back it stock?
Never were, probably never will either
The grubs on my TB 15t ones I just bought two months ago are m4
Maybe he did some changes. I need to measure them later.
Mine are from December 2018
Idk maybe, I only know because I had to buy those to put them on my BKB motors because the shaft is so short.
I agree though, the TB ones have always been solid
They will be, next batch of motor pulleys is 14, 15, 17, 18, 20
Did i hear 20T
14T!!! Yesss
When the nexus kit releases or thereabouts, hopefully soon
Yea, they’re arriving in a few days. 7" and 6" alloy wheels
Nice1
You once suggested I get pneumatics on reddit, and I was like nahh I want thane…
( ͡° ͜ʖ ͡°)
Now In Stock! (Whenever I get around to listing them…)
Wide 14" DKP Trucks & Evolve 63mm mounts
Bluetooth modules finally back in stock
6" and 7" Alloy rim pneumatics w/ Built-in pulleys on the back (Very nice imo)
In addition to this, @Acido 's battery service will also be offered through nexusboards, packs will ship directly from him to you as its very hard to ship from the UK to the EU
Do those wheels fit any pulley system out there? (Asking for geardrive obviously…)
Will you be stocking the new boardnamics gear drives?
Its a superstar pattern, but 60/66T pulleys are already built into half of the mould so you can’t really use your own, and I didn’t order any sets without pulleys. They’re 60/66T I think so there wouldn’t be a reason to swap wheel pulleys but if you wanted to use with GD for now I think you’re out of luck on these
