I’ve finally reached the point of throwing my hands up. I just want to ride. I can’t figure what’s going on with my board and it’s one thing after another. I originally had my sister’s ex start the build and after much dismay, finally got my board back 3/4 done. Problem being that I knew nothing about building and after immersing myself completely still at a loss.
Last little bit seems to be a pulsing with the motor. Any idea’s on what to do now?
That’s half the problem, he gave me nothing to go off of. Motors have no branding and he gave me no details on where it came from. I ordered the wheels, deck, battery, trucks, bearings and all that.
The vesc was preprogrammed so that already works. It’s literally just getting it to smoothly run.
Not sure if I may need new motor bearings, or hell even a new esc to stop the pulsing stuck motor.
You need to set you VESC, these do not come pre-programmed. You need a little bit more of patience or you migth get an endless set of additional problems, otherwise I suggest you pay someone to do it for you.
Looked like you got boned by your sisters ex. Where’s your battery from, and what are its specs by the way? I’d post your whole setup and more pics so we can look for any potential problems.
that’s not a vesc, its a hobbywing ecs which isn’t programmable by user, if it was designed for hub motor it won’t work on this setup
if its designed for outrunners, then the stuttering that motor is experiencing, u can try to swap around the phase wire to see if it gets any better, but i doubt it would get any better than that.
yup, that’s the fastest way to solve the issue, hobbywing esc isn’t a thing that u should be trying to figure out when u don’t even know where it was used before.
