new to esk8 and bought backfire g2t 6 months ago. I’ve really enjoyed riding it and its been good, but I’m what we call in cycling a clydesdale(235lbs). I want a board with more range and that can push my big a** up a hill so I’m collecting parts for my first build and any advice is appreciated. I’m comfortable with a reasonable top speed of around 25mph, which I’ve used the speed calculator to map out.
the whole vesc thing is a little intimidating as far as programming and I want to get the torque curve set up well. and not “let the smoke out of the box”
I’m was thinking of getting a usb extension cable and mounting a usb port on battery enclosure so I can adjust FSESC 6.6 without removing enclosure. Does anyone do that? Is that reasonable thinking?
I’d love to use bluetooth, but I read that the app is only supported by android and I’m an iPhone user, though I may have an ibm computer in the back of the closet. I’m sure it is bluetooth compatible, could I use that? and I assume you would need to purchase some sort of bluetooth module to add to the vesc? dang! I hope my wife doesn’t figure out how much this is costing.
I’m buying a prebuilt lion 30q battery. its so long that one of my concerns is deck flex, I’m waiting on blank maple deck that is supposed to be stiff, but the enclosure and battery may be stressed by my big a** which I’m sure will cause some flex
Having a way to directly connect to your ESC via something hardwired is ridiculously convenient - something you won’t be able to appreciate on your first venture into esk8. If you have the room in your enclosure… Do it.
The battery is the last component I have to buy. I had considered mboard, but decided to go with the one from diyelectricskateboard. One reason is it has power switch, charge port, battery level indicator and custom enclosure included…why?
I thought I had seen before people did micro USB extensions and the plug break due to vibration.
I would look into the Bluetooth module and maybe a cheap Android tablet. Just look up the OS requirements for the vesc tool app.
