I mean this is a limitation of the VESC design isn’t it? It’s supposed to cut out when you reach that 57V cutoff in vesc tool from what I remember
Someone correct me if I am wrong - I have experienced this before on my 12s fully charged, it’s pretty scary. Not much I can do about except ride it down till it is at like 97% and then after that I don’t seem to have issues
Correct - I should have been clear - this is not a failing of the NeoBox but rather I experienced a limit. @ShutterShock
My 12s Liion battery was at 47.1v when this occurred.
do you have a theory why the system reported the overvoltage error?
metr doesn’t show that the voltage reached anywhere near that high (47, 48v), and the motor speed wasn’t anywhere fast enough to generate that amount of back emf (under 10k erpm)
I had a dilemma today. My direct drives motors where to hot to drive farther. So I was thinking between wait or set my board off and start to push. But due those killed trampa vesc I have decided to wait
So that’s the reason why I now want to know how those neobox handle this issue
