Yes, you have. Get out of here with your ![]()
ā¦wish I could help tho, I feel like itās gotta be something simple, like when you lose your keys and they are in your hand⦠but I donāt knowā¦![]()
hahahha just cruizin hahahaha
Have we decided these can do FOC safely?
My Elofty drives are whiney with BLDC
100km foc with no problem
12s and 10s.
Nice
Probably around 200-250 miles running FOC on mine- no issues.
As of right now, whatās everyoneās impression of the neobox that has one and has been using it? Iām genuinely curious.
Negatives: case build quality, design and fit are shotty. Cuts themselves and finish are fine. Iāve had no issues with solder or wire quality, Iāve done worse myself TBH in the past, but not these days⦠Iād reflow and solder new wires if I demanded perfection and wasnāt lazy ⦠but mine work fine, no issues riding.
Neutral: If we could just purchase populated PCBs without case or wires soldered that would be
and just use our own enclosure mounted heatsink, or just offer a basic heatsink plate with a multitude of compatible mounting holes patterns as an option ⦠honestly the focbox case just worked way better and was a million times more serviceable.
Pros: They aiight. V6 vs V4 focbox is a noticable step up in performance compared side to side on the same build. Itās not 10S to 12S performance, but maybe equivalent to 10S to 10.5S or just 10S to 11S on the top end in terms of power response nuance at high speed rather than just more speed⦠forgive me, had a couple beers.
Iām happy with my purchase and happy I got them when I did. I was looking for focbox replacements to use on my focbox heatsinks, hoping they would perform better and they met my expectations there⦠if it were just my expectations they had to live up to though, they would be great- but all these other random āinnovationsā kinda detract from their value as a stand alone product. For what I needed though, right on the money and now I got a spare hunk of metal I can use as an ashtray @kook or rub them on my balls or something.
what if⦠for example hypothetically⦠somebody was to produce a bunch of āFocboxā boards and pair them with dual esc heatsinks⦠would that be of interest?
Hahhah⦠ummmā¦
If we get more focbox V6s⦠Iād take more V6 focboxes personally.
just cause I donāt need more builds right now, just need to spice up what I got
I removed mine from the aluminum boxes and use them on a 3d servisas heat sink and love them.
Smooth power delivery, good voltage readings (cough fuck flipsky).
The boxes are terrible, but they work as a heatsink pretty well. Im in Florida and itās hot as fuck.
They handle heat better than any esc I used so far.
I love the v6 design and definitely want more of them.
Iād buy more right now if someone trustworthy took the reins.
Can verify reliable builds are possible in our climate.
cough
@DerelictRobot save us!
Iām already on that missionā¦
The case abd heat-sink are seriously a joke! So poorly designed and not functional at all⦠The heat transfer tape in my enclosures donāt even touch the FETSā¦
ITāD be easy enough to fix just drill down a bit on the case stand off⦠And the stand offs are a joke⦠The entire case is built upside-down⦠But Iāve found a use for the cases
Felt like 112 today.
Same where Iām at 10 miles west of Orlando. IT was 95 and felt 115.
Im 2.5 hours south of you. Weāve actually met and ridden at the big meetup
god dammit my brain sucks. We should meet up and ride again.
As soon as these hellcats get here, Iām going to take the new board on an adventure around the state.
Iāll definitely get up with you guys Otown crew
Ran them for 200 km, its not that much, but for what its worth I havenāt had any issues at all. Thermals are better than the 4.12 single focboxes and the ride is smoother and more powerfull definitely at high speed. even reached 64 km/h on my mountainboard and did some hard braking, no cutouts or anything. They also work great with the metr pro module and the davegax, just had to swap the tx and rx pin on the davega cable.
Like mentioned by me and others before, the case design is not very optimal but other than that no complaints really. I might inspect the internals a bit better soon, check the thermal pads and swap the phase wires I dont trust the solder job for the long term.
