Currently on matrix 2’s with radium adapters on a flux deck. I was pushing 45mph on them so I’m looking for something stable at speed, don’t really care for carving that much. Also if anyone has any other truck recommendations I’m all ears.
i’m on the triple links rn and i’ve been up to 37 on em. they’re definitely stable enough to go higher, but i need to find a smooth road to do it on and i also have to balance my tires
These were an option i considered since im so used to channel trucks, does the standard matrix 3 motor mount clamp work or would i need a specific size.
Ehh it would fit with some shim material. Matrix III is a square as well, so I’m convinced they could be modified in some fashion to fit over the hanger reliably.
Nooot really. The wheel gear bearing (30mm ID) barely doesn’t fit inside the MIII profile. It would fit over if one were to file the R2 sharp edge ever so slightly.
