Anyone here having the MOSFET IRF7749L1TRPBF in spares?
I need around 50pcs
Just use a different FET?.
7748 7669 7769 Will work just fine, even tho thier rdson is slightly higher
From where can I order them?
Mouser, digikey, farnell.
Or you know just check octopart where they’re in stock
I had a look over the specs
The current rating is too low
How much current do you need?.
Trying to develop 80A Vesc
Choose something besides direct Fets then!
Theres alot of good options out there
Or you know, use more then 2 Fets per halfbridge
Thanks for your suggestion…
I have compared few similar mosfets…
I found IRF7739 compatible. Though the max rated voltage is 40v instead of 60v (7749).
P.s max voltage for my application is 30v. Can i use this mister?
typically 25% headroom is a good approach. so 40V is perfect for your 30V application
