ok this makes sense, i need the basics, Im new to all of this. how do i change the duty cycle. how does that work?
The safest course is not to limit speed in the software but rather via gear ratio/voltage/tire size/kv.
100%
If this info is correct, you are already at a 30-35mph top speed limited by your setup not software settings. (Inflated tire diameter may be larger than 155mm)
Ah thank you guys I am learning so much : )
I’ve done it safely.
Heu… i read on other thread to set the focbox unity to 60 000 erpm max and set limit duty cycles to 85%. This still implies even though erpm max at lower figures is dangerous? Thanks.
What thread?
Instructions unclear, penis caught in door
Really pulling for you…
I just re-checked the search topic and I read too fast the comments, it was for propeller boards. Oops. Me bad.
