Need help with a 2024 Acedeck Nyx Z1 (1036wh) conversion
Hey everyone, I’m pretty new to doing much esk8 DIY work, but I have one week to get my board fixed before I start school. I bought a Nyx Z1 that was broken and I’ve tested the components - battery is putting out strong voltage, motors are moving (at least while rolling the board around), but the ESC won’t turn on. I replaced the XT90 connectors thinking corrosion could be the issue but that didn’t fix anything.
At this point I’m just looking for any cheap option to get this thing running, any ideas of what may be best? I have access to a makerspace so I can do some DIY work there but I’m trying to keep costs down as much as possible with school and everything. Appreciate any help or advice! If anyone is also selling any ESCs or knows of anyone selling anything you think is compatible that would be awesome as well. Thank you everyone!
If the XT90’s are visibly corroded to the point that replacing them was thought to be a potential solution, then whatever happened to visible corrode teh xt90s had to do a number on the elecronicals.
If the XT90’s were burnt, and not corroded, well same thing.
Consider not keeping that board inside a residence, or below one, in case the ’strong voltage’ battery decides to do the Bumping uglies thing, with itself
