Need help removing 3dservisas pulleys
Hey,
I recently purchased the new 90mm boas and tried to fit my 36t 3dservisas pushfit pulley.
The core is one of the tightest i could test, and putting the pulley on was a real pain in the ass.
Now I’m trying to remove the pulley and it won’t move a bit, any idea how i can remove it without destroying the wheel or the pulley ?
Cheers
Someone wrote a thread on this
Some animals will use a hammer and pin push but A good set of Bike tire levers work every time for me :grin:
If you tap the pulley with a rubber mallet or rubber coated heavy pliers at an angle (rotating a little between each smack) it should eventually wiggle loose without any damage
I may have some laying around, will try.
And that did the trick, thanks for the advice :wink:
Nice!! No problem brother. I’m always happy to help :love_you_gesture:t3:
Also a vice is advised. :joy:
