Lost a couple of locking nuts for my trucks and cant seem to find proper replacements. I’m specifically looking for slim profile M12 Coarse thread locking nuts (cant find ant thinner than 10mm). These nuts come stock with the newbee RTKP trucks, but if a slightly thinner nut is available ill take em.
Try a low profile 5/8" locknut.
Axle nuts are usually imperial because it’s a holdover from the first skateboards.
Skateboard shops should have buckets of them.
I have some coarse thread M12 lock nuts, I believe 12x1.75 thread. I can shorten them on a lathe if you want but I wouldn’t be back for 2-3 weeks.
I thought about sending you a msg to have this done. I have the same nuts but they would be perfect if they were shorter. The way they are now, they are too long. Ordered a set from amazon that they asked me to keep when i attempted to return them ![]()
Try using the search term ‘jam nut’ or ‘lock nut’ or ‘locknut’
Be sure the thread pitch matches. Not all m12 are equal
Give McMaster Carr a look https://www.mcmaster.com/
gave it a try but no luck, so far it only takes M12 and the tolerances are ridiculous
Yea ive found plenty of nuts in the right size and thread, but all of em are too tall
Gave it a look but no avail, shortest they have is like 10mm
Hey I appreciate the offer, if i dont find anything till then ill message u
nylock jam nut. try fastenal if you have one near you. i almost exclusively get my hardware through them unless it’s specialty stuff they don’t have.
Find anything yet?
And @JustNeL still want some?
What should the total height be?
