Need Advice on Surfrodz Trucks
I have a single saffron hanger hanger, 200mm RKP.
I feel like they should just thread the actual hole and not use helicoil.
Nah. Helicoil is stronger since it has a larger engagement with the aluminum and is steel-on-steel with the fastener.
http://www.helicoil.in/pdf/helicoil%20catalogue.pdf#page=5
That just sounds problematic
ya need to install the helicoil properly and add a dab of thread locker… after locktite has set, run a tap slowly and properly back down hole! helicoil = much stronger than just cutting threads into ali…
new hangers are ordered!
…quick question about SR hangers - can you used them with Calliber 2 baseplates?
nope
