So apparently my charger died, first thought it was the battery but its all good.
Trying to find a new one but no luck so far. Thought about buying another straight from the eskate brand but they wanna charge $130 plus shipping.
OK, here is what you do. Talk to Luna fast bikes. They have a charger that has a voltage readout, so you could turn a pot to lower the cutoff etc. This would allow you to have an 80/90/100 switch, for doubling your battery life. You will need to verify though, that you can tune it for 12s. They have a 13s rating. That one is 99, the one without a voltage readout, is 59.
Personally I use the Meanwell HLG range and build a higher quality DIY charger (bare in mined thay won’t have a charge cut off (most ESK8 charges don’t) and you will need to adjust the pots to set the Amps and voltage to your desired level)
My BMS’s on my boards cut the charge when full so it’s not a concern for me.
