Need a jet kill shot and enclosure.
Assuming you have already tried the master @Sender
Sender
4
I have them, but only higher end customs. No plain decks.
These are available with @BigBen FG enclosures.
ahrav
5
@Sender how much do these go for I don’t even need a deck but …
Sn4Pz
6
It’s varied pretty widely for my two decks, so unless you give him a deck to base it off of idk how useful a ‘rough estimate’ would be
E: unless you’re talking about the decks above… Woops
I want a @BigBen killshot enclosure soooooo bad!!!
@Sender is your man. No decks available here.
Also @Winfly has an extra 38
ahrav
9
Hahaha np. I was asking about the decks in question above. Sorry should’ve been slightly more clear.
Sender
10
These are $435 with mounted Fiberglass enclosure, mounting hardware, and matching fender washers
Your second deck was a PITA. Routing channels all sorts of shit. That is much more involved than a skin job.
Sn4Pz
11
I wasn’t saying otherwise
ahrav
13
@BigBen can I get two unities in the killshot enclosure with 12s4p 21700 cells???
BigBen
14
I’d need to do a layout to check unless @Sender gets there first.
Sender
16
I have all that on hand. I can check in a bit
DEEIF
18
@bigben how big of a foam spacer would be needed to fit dual OG Focboxes and a 13s6p 21700 batt?
ahrav
20
Fuck that looks more than cozy. Ahhh shiiiiiittttt.
