Bamboo splits. What matters is whether or not you stuff this split with glue, epoxy of wood fill. I was being lazy here and just did it with epoxy. The refined way to do it would be to use a matching wood fill and then sand it and make it look pretty.
Oh, does it split when you press? If so have you tried veneer conditionner? I have seen @longhairedboy say thAt he uses it and helps avoid splitting during the pressing.
Bamboo is just a bunch of fibers pressed together with glue. Splits are kind of a reality, especially if the veneer gets dry. When layered and glued it just fine.
So, I don’t use conditioners on skateboards. I’m not saying that you shouldn’t. I just don’t. Conditioners are used to bend veneers in extreme ways for furniture and art. Using them on skateboards is a debatable subject. Essentially, they degrade the integrity of the material in order to make it more flexible. Debate away…
Not going to debate and just so we are clear, I wasn’t trying to attack your work. I work with wood so this kinda stuff is really interesting to me and I take this opportunity to learn more. I can take my post back but your explanation wouldn’t make sense if I remove parts of it.
No don’t remove it. It’s a good point and I’m happy to clarify things. If this were a bare deck with a gaping split in the top that you could run your fingernail through,I’d be a hack.
Your cool with me @Tamatoa. I welcome the questions. I apologize if I ever shoot from the hip with my responses. I worked as a chef for nearly 20 years. I have trouble candy-coating things. I realize that I should work on that, but, unfortunately, I mostly just spend a lot of time apologizing
Everything is fine then, awesome work so far looks like a lot of fun to make these decks, keep it up.
I wasn’t thinking when I made that post, sorry y’all
But yeah, it looks and feels solid. I don’t have to do the knife scratch because I can see that it’s fully enclosed by the finish too
Started a small build and review thread over here:
@tomiboi do the decks come with a hole for phase wires or do we have to drill those ourselves
“chéri”
In the future there will be holes. I just wanted feedback on where to put them.
Could there be an option for drilled and non-drilled decks, so that those who want can do it themselves?
Do less work? Twist my arm.
Are you talking about the trucks holes? Wouldn’t you prefer a well tune cnc position the holes for you? I could trust myself with a paper template and a hand drill to align my drive train but there is a high risk of messing it up
No for wires and ports
I’m thinking of drilling 3-4 perfectly angled 1/8" pilot holes in the back of the compartment. Drilling them out to your preferred size with a hand drill would be easy from there.
Quick question for everybody testing, got the protective gear to push these decks to the limit?
Yup
Ive got
New Olders
TSG DHP kneepads
Arnoured hoodie
And the right falling technique
Don’t forget balls…
