My Esk8s. A journal of sorts
Yesterday was butt ass cold…
There was no riding except the Onewheels in the house.
Late at night I got to working on the Third Demonseed.
I put Razillian’s Precision DKP trucks together.
There is no comparison really between cast parts, and these buttery CNC parts.
But I still wanted to see them together.
To be fair the Evolve trucks have hung around for over 5 years now and have seen a lot of different set ups and some pretty serious miles…
I am going to need some more 10mm spacers…
This grip tape was inspired by Al’s board. @glyphiks
I was trying not to copy, copy it…and I am really stoked on how it turned out.
The hold up on this board has been kinda silly.
I needed to drill out the adapter clamps Razillian sent me.
Which means I needed to go my father in law’s house… Which is across town…
Yada yada yada… I ordered nice mounts from @IDEA because these trucks seem to deserve nice parts to go with them.
So soon I will have something a little like this…
Which I am super stoked about.
Makes me want new motors to go in here to make it all shinny and new…
I actually have some new 6374s… But I really think 6354s are a better fit here to not add a bunch of weight…
So I have to take a little pause until I get the mounts. But I am pretty anxious to get my DKP vibes on… Even though thane riding takes a major hit in the winter…
I did get out and ride a little bit today.
School pickup which was nice.
Got to 44 and was sunny.
And a little bit after work… But the temperature was tanking…so I just did 7 miles.
I have been doing this a bit and it keeps working. I have been able to change remote hands and hold the Z.mote with my left hand.
Huge help with the cold.
And now I’m going to mess with the Gravel Boi some…
Well.
My adventures tonight didn’t work out…
I did take the Gravel Boi apart.
And I put grip tape on it which looks cool.
And then I got going on installing the 4GS.
And it was a delight because the parts are awesome and go well together…
And then I hit a snag and have to stop…
The Flipsky 6374 BH 140kv motors have a 10mm portion of the shaft that sticks out 8mm so the motor pinion can’t sit far enough…
So I need to get new motors for this board…
Diy is a disease…
I wanted 6384s anyways…
Onto the wall goes half a board…
It can wait for parts with the Demonseed…
Axles are easy to replace though, unless all of the flipsky 6374 stepped like that?
@Boardnamics do you have any 6374 axles you could sell Rafael?
Edit: see you’re using newbee - I’m not sure if BN motor axles have that step or not…
I think @rafaelinmissouri is referring to the motors axle right? Not truck axle?
What do you mean by this? Can’t you cut it down to fit?
Edit: never mind I read this as key
I tend to think of the idea of changing a motor shaft as being hard to do.
I had not really gone in that direction of thinking.
But you made me think…
And I went in the closet and I have several other Flipsky 6374 motors.
And sure enough they also have stepped shafts.
I have some old maytech motors but they have 8mm all the way…
So yeah.
These motors and the Newbee drives will not be a go.
That is unfortunate.
@Ean.esk8 Perhaps worth noting on your website that the 4GS are not compatible with flipsky motor stepped shafts. Not your job to tell people about other vendors, but could prevent someone else ending up in Rafael’s situation.
One solution I could go to is getting the 6384 140kv motors from Boardnamics.
They are not stepped.
They are what I use on the Gravel Flux.
Be about 230 bucks.
I actually kinda wanted 6384s on here… Since it’s a decent battery here.
But for some reason this was the last straw for this board…
I thought I was done buying stuff for it. Which got super out of hand as it is.
I have issues…
So I think the Gravel Boi is going to stay on Matrix II and get some belts.
Which makes me a little less excited about it.
So this snag was a bummer.
But here is where it’s going to go. or I think it’s going to go…
The Flux will get some upgrades.
I have been wanting new motors for the Flux…
And now seems like a good time for that since I need new motors for the Drives.
So the Flux will get Matrix III when I can buy them.
And the 4gs drives which will be nice.
And hopefully nice juicy new motors.
Sorry for this happens, man. But if you or your friend have 3d printer, i could send you the file of motor plate spacer. But base on the photo it would bring another problem…the shaft seem bit too short.
It’s ok.
I will make these work with other motors.
Son of a bitch dude…
I really want to build one of these Funwheel STs
Like badly…
Looks pretty dope, and that subtle w concave sounds enticing
My new friend with the Vesc Onewheel came over today so we could put a new tire on his Onewheel.
It’s is pretty fun to tinker with someone.
Then we went and rode and I did 6.5 miles.
He really flies on that tiny little Onewheel of his…
Made me want a Vesc Onewheel even more because it would be pretty cool to cruise closer to 25.
Tonight I got into my own tinkering a little bit.
I’m getting into the Gravel Boi and the first order of business is stealing the 68tooth pulleys I had just put on the Flux…
Something I sometimes get real joy out of in doing diy is when I happen to have the perfect length bolts and the nuts line up nicely.
Celebrate the small victories!!!
And I went and took the box apart…
Lots of work to do now to get it back together…
I probably won’t get into that tonight.
Phase wires on the unity were getting tugged/smashed…
Not sure what was doing that…
I think it’s ok.
Okeydoke…
I got the drivetrain assembled, so I could get a preview of how it’s going to look.
I like it.
I expect it will run well.
I really think I would have been more excited with the NewBees on here because the tail would look so much more sutil with those tiny drives.
I’m still going to chase after a nicer case.
But may very well try to assemble it with the Junction Box just to get it going and change that later on.
It may be hard to do the wires how I want to with how crammed that box is.
Oof, lucky you discovered it before something worse might have happened.
Those @IDEA mounts look mighty fine :ok_hand:
Yeah… I much prefer not getting thrown off my board… Still not clear what did it … wonder if tugging could do that.
For sure. It looks as if the silicone sleeve has just been pulled away. Tugging or a lot of side to side movement could do that
