Back story:
My electric unicycle consists of two battery packs. (One on each side of the wheel)
Each pack has their own BMS. (proprietary gotway bms)
The discharge ports to the ESC is hooked up in parallel. The charge ports is hooked up in parallel
There is a BMS “signal cable” that joins the two BMS’s together in case one battery pack goes wrong
One pack goes wrong…
Had a dead group in one of the packs
Both the packs stopped charging at 23s (24s normally). The BMS overcharge circuitry behaved as expected.
I did a test by disconnecting the “signal cable”, and both packs started to charge over 23s. (overcharging the dead pack slightly to 4.25v) I ended the test immediately and discharged until they were 4.2v.
I ended up replacing the 2 cells in the dead group and all is well and both battery packs are healthy and working as expected
Conclusion:
- had there not been this “signal wire”, the bad battery pack would have charged to 24s full! (4.38v/cell which is dangerous)
Question:
I am adding a 3rd battery pack because there is space in the enclosure, and I am putting one of these regular BMS’s in there (this) or with (bluetooth).
But these ones don’t have the proprietary “signal cable” that lets other BMS’s know to stop charging in case i get another dead group
If this same scenario happens to some of the guys on here that are paralleling packs, would they charge to dangerous levels? Since all of our BMSs are cannot communicate with each other (guys over here)
Is anyone here a BMS expert that can chime in and shine a light on this topic?
Thanks
