Return that one, get a double stack and cut it to fit.
I have already drilled it, too bad I didnāt think of that first. I am determined to make this work without sacrificing space.
Do you know how to fiberglass? If so, wrap that one and make the sides up.
I donāt, I saw a couple videos and thought this might be easier. I might get adventous one day and attempt it.
Lemme know if you canāt get it.
I will, I really appreciate all the willingness to help out a stranger.
Heās not a stranger, just strange.
Itās not too late to use the ABS as a buck to lay fiberglass on top of. Then your new fiberglass enclosure has a nice ABS padding ion the inside.
This is true, the hard part would already be done, still a little intimadated by the the fiberglass. It would be double unforced though.
So I wanted to use 12s3p samsung 40t with this BMS: https://www.lithiumbatterypcb.com/product/12s-13s-14s-15s-36v-48v-58-8v-smart-bluetooth-bms-with-20a-to-60a-constant-discharge-current-with-uart-and-rs485-double-communication/ (12s 30A), in boundmotorās carbon fibre deck: https://boundmotor.com/product/carbon-fiber-skateboard-deck/ , on website they say that you can fit only 12s2p pack of 21700 cells but iām quite sure that I can fit 12s3p too. Can someone doublecheck if thatās possible because this is gonna be my first battery pack and Iām a little concerned?
