I have some L-Faster mbs clone trucks and i want to mount them on my MBS COMP 95 deck, that has a 35 degree tip angle.
Do i need to use those Riser pads that are included with the trucks or should i mount them without the Risers?
Look at the pad, it has an angle to it. If you do use it, it will affect how the truck turns. Angling it higher up, makes it turn more, and vice versa, turns less.
I recommend having it angled more on the front, and angled less at the back.
What linny said but you could also opt to just not use it. As the deck already has the required angle for these kinds of trucks.
Since it’s an angled riser i would assume that one of it’s main use cases would be the use for non ideally angled decks
Thanks guys!!
