Mount/Belt Asymetric Differential
Saw this today in the FB Electric Skateboard Club. Interesting solution. You think there maybe an issue or does it really work? Thoughts?
It’s dumb and unsightly…but I suppose nothing technically wrong? It’s usually a sign of loose mounts through or bad assembly
Won’t you get higher voltage dumped into the ESC if one of the motors is traveling higher than it’s supposed to at it’s given ratio and kv? (Assuming they’re different)
Doesn’t seem like a good idea, based on that. Otherwise… Frankenstein away :man_shrugging:t2:
Weird science :thinking:.
