Hello. I built an eSkate about a year ago and I haven’t used it in two months as I broke my arm. I recharged it and the motors slightly humm but don’t spin. I did a reconfigure using VESC tool and the motors turn normally and complete the test with success. I then attempt to use the controller and the same humm happens without movement. Any ideas for troubleshooting? Thank you in advance.
I should also say, after successful calibration, the forward/backward buttons don’t work in VESC either. The only movement I get is calibration testing.
I tried the calibration; however, still couldn’t get it working. Nothing shows on the input graph when I am moving the throttle rocker. Any other suggestions as I am sure it must be a setting? Here are the results of the detection process.
Ok so under the right side column ull see APP and the click around under the settings tabs until you see a drop down for app to use and try ppm then uart then ppm and uart and what not.
I got the motors working when I test in VESC by adjusting the voltage cutoffs, but still no cigar with the remote. The VX2 says is connected but doesn’t do anything. Yes, I have gone through setup input but nothing appears to happen.
