Hi guys!
I would like to share with you my design of motor mounts.
The main goals were:
Easy to replace wheel (easy to lose belt and change the gears)
Belt tensioner by the screw to prevent wrong belt tension
Compatible with 50mm and 63mm motors
Wide range of belt lenght use
Possibility of mounting two 55mm long motors on one truck
Space (extra holes) to mount belt cover or crossbar
Check the pictures below. It is compatible with caliber II trucks. What do you think about this? It is early prototype, need to design belt cover and minimal motor mount design improvement.
It looks to me like it’s just standard sliding tensioning like torqueboards ones but I could be wrong. I like how Hoyt or trampa or the others do it too like you were mentioning.
Please check the video how it’s work. The screw to tension the belt is need only when you doing tensioning. For normal use you can unscrew it.
The belt width is defined by type and number of motors. For 2x55mm motors in one truck the belt must be 9mm width (there is no enought space in normal caliber truck hanger), however if you use one bigger motor you can go with 15mm or even 20mm width belt.
Looks great be nice black anodized, are you selling them ?
Maby the 4 fixing need to be in a slot like dickios? So the bolt clamps better.
Best motor mounts I’ve seen.
Put me down for a black set.
Thanks man, I’m need to check dimension of the Boardnamics hanger. It’s is a copy of caliber truck, but longer? I never had it in my hand.
I need to think about the diagonal clamp, but I’m not sure it’s better option
