My build has been having some strange issues lately and I figured I would reach out to the hive mind for help.
I have a single 6374 motor with hall sensors connected to a FS6.6 VESC. It it’s setup to run sensored FOC.
Very recently it has developed some issues at low speed. The motor starts turning like normal, then it seems to catch, then it continues like normal. Once it gets past the transition to sensorless, it works perfectly.
This obviously lead me to believe that one of the hall sensors is messed up. So I took out my multimeter and measured the DC voltage difference between positive and the signal pins from the sensor. All three signal pins alternated from +5v to +0.5v as I rotated the motor.
Then I went into VESC tool and ran a hall sensor detection. It successfully ran, and I applied those settings. Still no dice.
I ran the tool a couple more times and recorded the results to see if they varied.
Here are the results
Run number | Sensor 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7
1 | 255 | 149 | 18 | 181 | 84 | 118 | 50 | 255
2 | 255 | 148 | 15 | 180 | 87 | 116 | 45 | 255
3 | 255 | 146 | 17 | 179 | 87 | 116 | 48 | 255
4 | 255 | 147 | 17 | 179 | 86 | 118 | 49 | 255
All of the results seem very similar to me, but I don’t have a functioning board to compare them too.
My VESC configuration and firmware has not been changed except for the hall sensor configuration and using profiles in the official VESC app.
And now for the kicker: While making this post I turned the board off and let it sit for about 2-3 minutes. I turned the board back on for shits and giggles, and it works perfectly.
Now I think that the issue was either caused by changing profiles, setting a profile as “use until reboot”, or overheating in the VESC as the issue only seems to crop up after having been ridden for a while.
