Motor broke on my first ride
flipping the mounts.
Without changing out the setup too much my suggestion for how you can avoid this in the future with a similar setup would be a larger wheel than the cags you’ve got on it. Would raise your motors off the ground a bit to avoid the motors hitting things and causing future broken magnets. Maybe try a popoca 90mm or a 100mm boa to give it some lift off the ground.
