For sale used Made in Germany by Lehner Motoren Technik BLDC motor Torqstar 3, 20 KW, from 2000 up to 14 000 RPM, outrunner with air cooling.
Working voltage: 48-96V, 20 Magnet Poles, 12mm shaft. Fully tested with VESC and ESC, custom industrial construction edition with ceramic bearings which are designed for 100,000 hours of operation, temperature sensor.
Comes with 6 month of warranty.
Shipping from EU by express courier service.
Price: 400 EUR
This one doesn’t have coolant ports
No, no. This one is another one without the water cooling, as tech.shit rightly pointed out. I thought about adding to previous thread, but I’m afraid people will get completely confused. If you think they should be merged with the previos one, we can do that, no problem. Just tell me if you want, I will add to previous, and you will delete this one. I’m not doing multi posting.
looks like i found a way to be confused.
sry.
people do separate and same threads for different things. it’s up to you.
