-More chamfers all around. Doesn’t dent as easily
-Slightly better surface finish
-Hole for the axle a little bigger, less likely to get stuck.
-Pivot nose doesn’t scrape against caliber II baseplates anymore.
220s for $75 a set. 184s for $70 a set. Both available raw and anodized now. Comes with fixed axles.
Got more adjustable baseplates, but they manufacturer made an error. The hole for the bolt to set the angle is off by 1mm on each one. epic fail They all have to be remade
Kind of bad news. The manufacturer really messed up. The hole for the bearing is not perfectly round. A lot of wrong tolerances. It’s all being redone but I’m disappointed.
I spend like 30 minutes measuring each part and there’s soooo many errors. Gear drive will be delayed for now
Fun story. Ordered around 1000 clamps for caliber II motor mounts. They all came without holes. They fixed it but…wtf? How can this pass any kind of QC? It’s a major feature of the part
