Test Report Summary: This cell is a good performer, equal to the classic Samsung 25R6, but it is overrated. Based on the model number on the other side of the wrap this appears to be the Sinowatt 25SP, a 20A 2500mAh cell. This Imren is also identical in appearance and performance to the Efest 25EF, which is rated 20A.
The two cells I tested delivered 2660mAh and 2662mAh. This is great consistency and exceeds this cell’s 2500mAh rating.
Two cells were purchased for testing by me.
Ratings graphic: Imgur: The magic of the Internet
Full Test report: https://bit.ly/3ivJCXN
I want to work for the community full time! If you feel what I do is worth a couple dollars a month and you would like early access to battery availability, battery and charger testing and news, and a say in what I test, then please consider becoming a patron and supporting my testing efforts: Battery Mooch is creating battery and device tests | Patreon.
These tests only note my personal ESTIMATED ratings for these batteries at the time I tested them. Any battery that is not a genuine Samsung, Sony, Murata, LG, Panasonic, Molicel, or Sanyo can change at any time! This is one of the hazards of using “rewrapped” or batteries from other manufacturers so carefully research any battery you are considering using before purchasing.
Misusing or mishandling lithium-ion batteries can pose a SERIOUS RISK of property damage, personal injury, or even death. They are not supposed to be used outside of a fully protected battery pack and you use them at your own risk. Never exceed the battery’s true continuous current rating and keep the plastic wrap and top insulating ring in perfect condition.
Testing batteries at their limits is dangerous and should never be attempted by anyone who has not thoroughly studied the dangers involved, understands the risks, has the proper equipment, and takes all appropriate safety precautions.
To see how other cells have tested check out this link: https://www.e-cigarette-forum.com/forum/blog-entry/list-of-battery-tests.7436/
