Where I can buy a new one from the EU and what’s the wiring diagram? I noticed that most of those switch are 4+ pin but the Flipsky use it with a 3 pin jst…
With the Anti-spark, do you know if it is a momentary switch or a latching switch?
If so, you can find some easy by typing in Latching/Momentary 12mm switch on Ebay, Amazon, Aliexpress and find which one you like, thats 12mm and circular.
If you want the LED to work / switch to light up, make sure you get the voltage correct on the new switch. Otherwise the LED may burn up the second you plug it in.
Looks like the Flipsky Anti-spark 3-pin switch has relay power (K+), LED power (L+), and common ground (-). You could get any voltage switch and not hook up the power to the LED. Or get the correct voltage and have it work normally.
Assuming +L means voltage for the light on the flipsky antispark; then yes – red K+, white L+, black is negative L and K. Same red-white-black ordering on the connector.
