30 bucks not bad
One thing to consider if it is possible, you may want to flip the chain 2 prong hooks around so the prong part rests away from the tire. I’d be scared it’d wear through the tire wall.
Vs
Could be nothing, could be a set of tires
it seems to make this work with BN AT drives you would have to make the ring on the inner side wider, and keep it from hitting the gearbox. Not sure… May not be worth the trouble.
