Surprised to find the compatibility of ENNOID-BMS.
Seems to be more mini Slave board: 10060mm, Master Mini board: 8582mm
found an aliexpress link with more info
Price is OOF, but stacking multiple balance modules to customize it seems really cool (unless that was just done for a pretty photo)
Price is OOF i think so too.
Looks like an aluminum substrate , Maybe the heat dissipation effect will be better.
Stacking multiple balance modules can be used with higher S battery packs, 1 is 12S, 2 is 24S, and 3 is 36S. Pack configuration examples:
Master-LV monitoring 23S pack :
- 2 x LTC6811-12S : 12S + 11S ( Optimal)
- 2 x LTC6812-15S : 12S + 11S (Two slaves partially loaded)
- 2 x LTC6813-18S : 12S + 11S (Two slaves partially loaded)
Master-LV monitoring 27S pack :
- 3 x LTC6811-12S: 9S + 9S + 9S (Three slaves partially loaded)
- 2 x LTC6812-15S: 14S + 13S (Optimal)
- 2 x LTC6813-18S: 14S + 13S (Two slaves partially loaded)
Master-LV monitoring 29S pack :
- 3 x LTC6811-12S: 10S + 10S + 9S (Three slaves partially loaded)
- 2 x LTC6812-15S: 15S + 14S ( Optimal)
- 2 x LTC6813-18S: 15S + 14S (Two slaves partially loaded)
I read it from Ennoid’s blog post: ENNOID-BMS setup
i found from here with the same info BMS Board Price, Buy Smart BMS Based on ENNOID-BMS - Free Shipping
